static rpm drop
Gfeldman
Hi All,
I'm hoping that you can help me solve the following issue. Two days ago  at 10:00am on a 35 mile flight in my Phoenix the Rotax produced >5000rpm on before roll started on takeoff. On my return flight I noticed a max rpm of 4800rpm even after leveling off. I thought the density altitude could explain the difference as it was about 10 degrees warmer on my return flight. Yesterday I did a static runup on the ground in cooler air and found max rpm to be 4700-4800 rpm. There was the expected mag drop and increase when each mag was tested separately at 3000rpm. I plan to check for possible fuel contamination.
Do you guys have any other thoughts?
Thanks
George Feldman N33GF
Was the engine running smoothly at the reduced RPM? I've have the RPM drop 500 rpm a few times, but there was always extra vibration.
Could it be the RPM is correct but is being indicated incorrectly?
Try asking on the Rotax Owners group, too: https://www.rotax-owner.com/en/forum
Eric thanks for this tip.
After my last post I flew the Phoenix around our pattern 1x and found that on the takeoff roll I was getting 5050rpm substantially higher than the 47-4800 I got on static run up. No discernible vibration at or below 3000 today when I flew 45 miles to my A&p for its annual. I will have him sync carbs and ck them.
George
