Jordan Posted February 6, 2018 Report Share Posted February 6, 2018 I am interested in purchasing a TMG for personal use and I wanted the advice from some professionals. Does anyone have any literature about takeoff requirements? I have a big field in my backyard and I don't know if it will be large enough for me take off. The widest it gets is about 150 feet with trees all around. I am still looking into which airplane I will purchase. Quote Link to comment Share on other sites More sharing options...
Guest airusa Posted February 7, 2018 Report Share Posted February 7, 2018 Give me a call and I will give information about the SunDancer performance. Joe Kulbeth at 559-960-7873 Quote Link to comment Share on other sites More sharing options...
Sinus Flex Max Posted April 8, 2018 Report Share Posted April 8, 2018 Check the performance specs of the gliders you are interested in. For example, Pipistrel Virus (13 meter span) at 1320 lbs MTOW, 1510' over 50' obstacle. Add 20% for grass, add more for less-than-perfect technique, add more for a safety factor. For Pipistrel Sinus (15 meter span), the published figure is 1312' and the same comments apply. Keep in mind that if you ask the local authorities for permission, they will likely say no. If you do not ask permission, you may be ignored unless a third party complains. Quote Link to comment Share on other sites More sharing options...
