carl goodier Posted November 22, 2019 Report Share Posted November 22, 2019 Looking at 2 TMG's, one with a Rotax (water cooled) which I am familiar with, and one with a Sauer 1800 (air-cooled) which I am not familiar wth. The Sauer seems to have Aircraft certification to JAR which improves my confidence in it. can anyone share its experiences, especially in hot environments ? I know Jabiru uses air-cooled engines too Quote Link to comment Share on other sites More sharing options...
brasov Posted December 22, 2019 Report Share Posted December 22, 2019 Hi Carl. I have not flown behind the Sauer engines but I have over 5,000 hours behind air cooled 2165 cc VW engines in my Brasovs in temps ranging from 20 to 100 degrees. The Sauer engines are very similar to what I have. If the upper cowl deck is sealed meticulously so all the incoming cooling air has to go downward through the heads and cylinders, I have found cylinder head temps have not been a problem. But I have found oil temps on vw can go high on hot climb outs. I added an extra oil cooler on firewall similar to a c-172 installation and that solved all problems for me. The original vw oil cooler on top of engine is in series with the oil cooler on firewall So I think you would be fine with either engine. Arlan Quote Link to comment Share on other sites More sharing options...
